Gadget user interaction
Postby jimandi5000 » Mon Oct 28, 2019 8:30 pm
Hello all,
I need some help. I have built tools for AutoCAD and there are code functions to get input from the user. (i.e. Getpoint, Getobject, Getangle etc...) I am looking for the same in Lua. Anyone have these or know how to make them?
AutoLISP Examples
(setq p (getpoint))
(setq p (getpoint "Where? "))
(setq p (getpoint '(1.5 2.0) "Second point: "))
Jim
jimandi5000
Re: Gadget user interaction
Postby Adrian » Tue Oct 29, 2019 9:16 am
Far as I know the only way with LUA as it's used with Vectric to get user input is to use HTML and the associated get/put functions. The standard io read functions don't work as the there isn't a command line to capture info form and other methods require other libraries which is more hassle than just popping up a simple form.
Postby jimandi5000 » Tue Oct 29, 2019 12:18 pm
Adrian wrote:Far as I know the only way with LUA as it's used with Vectric to get user input is to use HTML and the associated get/put functions. The standard io read functions don't work as the there isn't a command line to capture info form and other methods require other libraries which is more hassle than just popping up a simple form.
Thanks Adrian,
Jim
jimandi5000
Return to Gadgets - General
Users browsing this forum: Wayne Locke and 1 guest
