Box joint gadget.
Box joint gadget.
Postby cusoak » Fri Jul 19, 2019 2:09 pm
Can the box joint gadget be used to make a box where the only place the fingers are, are on one edge of the sides and on both ends of the bottom the lid will be removeable
I want to be able to route a grove for glass in the front and a grove in back for a piece of plywood?
Jeff
cusoak
Re: Box joint gadget.
Postby Adrian » Fri Jul 19, 2019 2:32 pm
Doesn't the flat lid option do that? Not sure as I don't use the gadget but reading the documentation it would seem to do what you want.
Postby cusoak » Sun Jul 21, 2019 2:12 pm
The attached file shows 2 sides and bottom ,
The ends with finger on them is where I want to cut.
Is it possible to use the box joint gadget to do this.
Jeff
Finger joint placement.crv
(158 KiB) Downloaded 19 times
cusoak
Postby Adrian » Sun Jul 21, 2019 5:49 pm
The finger joints are just normal vectors and toolpaths so you can remove the fingers you don't want via node editing and then recalculate the toolpaths.
Cut on the top and bottom node on the side where you don't want the fingers, select and delete the finger part that is cut out and then use the join with a straight line tool.
Postby cusoak » Sun Jul 21, 2019 10:44 pm
Thanks Adrian after I posted the file I got to thinking and thought about node editing, but I would have thought about connecting with a straight line.
Jeff
What I wish they had was a finger or box joint gadget that was cut with the wood being held verticaly.
cusoak
Postby Adrian » Mon Jul 22, 2019 8:11 am
Vertical is a very easy toolpath to do by hand (as is horizontal to be fair). It's just a series of rectangular vectors with the depth of cut being the depth of fingers. Lots of people on the ShopBot forum do them. There is a program to do them as well but it's not a gadget. Once you've done one manually though it's so simple to adjust from there to any size you probably wouldn't bother with a gadget anyway.
Postby cusoak » Mon Jul 22, 2019 2:37 pm
I will look on the ShopBot forum for more info .Will what ever shows up there going to be using vcarve pro
Any way this is what I did with the box joint gadget buy cutting the vector I did not want and connecting with a straight line
The file also shows the tool cut out tool path. Will need to add a rabbit for the back and plexiglas front.
But it was pretty easy to do
Jeff
Finger joint bottom and 2 sides.crv
(195 KiB) Downloaded 18 times
cusoak
Postby TReischl » Mon Jul 22, 2019 4:25 pm
Here is how I do them on a vertical jig on the front of my machine:
https://www.youtube.com/watch?v=NhLkB1ZyOPo
I do that cutting in the first part of the video to prevent splintering and tearout. Essentially what it is doing is walking around the outside corners using a climb cut. Then when it passes straight thru there is no material that will splinter out. That is pine being cut in the video which will splinter very easily.
http://www.tedreischl.com
Low Profile CNC Router Vise
Postby cusoak » Tue Jul 23, 2019 1:17 pm
TReischl Your video shows just what I want to be able to do.
My shapeoko will travel beyond the front of my machine far enough to be able to cut the thickness of wood I want to use.
I like the tool path you came up with to do the cuts around the back and front first. To keep the tear out from happening.
Did you create that in vcarve. Would you mind sharing how you did that tool path.
Thanks Jeff
cusoak
Postby TReischl » Sun Jul 28, 2019 10:12 pm
Cusoak:
Here is what the tool path vector looks like:
I usually climb mill around it rather than what is shown in the picture. I also normally move the two end lines (vertical) out a bit from the stock size so that if I need to adjust the bit size to get a good fit I don't start cutting into the edges of the boards.
There is also another variety that I showed in the video, just split the vector up and have it do a loop on one side of the board at a time. These days I generally do it the way I showed it in the attachment, it is faster because it is not cutting air so much.
Postby cusoak » Mon Jul 29, 2019 11:03 am
So is that vector just the cut on the outside.
Jeff
cusoak
Postby TReischl » Mon Jul 29, 2019 1:06 pm
cusoak wrote:So is that vector just the cut on the outside.
Jeff
Yup, that is all it is. The climb cut is important, btw. What is happening as you can see is the tool is walking around the corner when it enters the material, when it gets to the opposite corner it is pushing the wood into the stock. So, the result is no chip out. It takes longer than just cutting straight across, but finger joints go fast anyhow. You can cut a lot deeper in one pass because you are side milling.
Postby cusoak » Mon Aug 05, 2019 12:51 pm
Well I ran the box joint gadget yesterday and cut out a box. And of course it did not fit together. joints to tight.
So I was using .25 material and an .125 end mil in plywood.
I did not put anything in the allowance box.
So my question is this.
IS the allowance bases on anything other than just a guess
If that is correct what might be a good starting point for an allowance.
Jeff
cusoak
Postby TReischl » Mon Aug 05, 2019 1:18 pm
cusoak wrote:Well I ran the box joint gadget yesterday and cut out a box. And of course it did not fit together. joints to tight.
Of course it is. And no it is not. End mills often cut something other than their stated size. They could be undersize or oversize and they may not run true in a collet. Wood is different in that it has fibers and those fibers can be springy, push down, pop back up.
Hard to say actually. But keep in mind that when you adjust size you should always recut both pieces. That said remember that any size adjustment you make is actually quadrupled. Each side of the slot on both pieces. So it is advisable to make very small changes, like a thou at a time unless you can see that it is REALLY off.
Jeff
Postby WNC_Ed » Mon Aug 05, 2019 2:18 pm
Ted, great point and worth repeating ... so here it is:
Maker of sawdust
WNC_Ed
Next
Return to Gadgets - General
