conical fluting toolpath
Postby RayHari » Mon Dec 24, 2018 10:29 pm
I want to create a conical fluting toolpath. The moulding toolpath creates a non-tapered toolpath if I give a straight line as the rail and a semi circle as the profile. I want the same except the radius of the semi circle should change from one end of the rail to the other from 1/2 inch to 1/4th inch. Is there a gadget available for this? I am using VCarve Pro 9.512 for shopbot.
RayHari
Model of CNC Machine: ShopBot desktop max
Re: conical fluting toolpath
Postby RayHari » Sat Dec 29, 2018 1:47 am
:cry: No one knows how to do this? Please help.
RayHari
Postby highpockets » Sat Dec 29, 2018 3:08 am
Your description is a bit confusing (at least to me). A picture or two would do wonders in getting help with a solution.
Postby Adrian » Sat Dec 29, 2018 9:53 am
Not many people read posts in the gadgets section as it's very specialised. You might get more responses if you post in the VCarve section with a picture of what you want to do. Quite often there is a way of doing things with a combination of toolpaths that doesn't require a gadget.
Postby scottp55 » Sat Dec 29, 2018 10:12 am
Yep....pics/sketch better for pre-caffeine numbiciles like me:)
scottp55
Postby FixitMike » Mon Dec 31, 2018 10:54 pm
You can do this in Aspire with a 2 rail sweep. But it is beyond the capabilities of VCarve as far as I can tell.
FixitMike
Postby scottp55 » Mon Dec 31, 2018 11:12 pm
Still need a sketch...thinking something like 4D's Fluting Toolpathing a cork stopper shape,
Used that a couple of times for odd stuff and worked great once past the first plunge toolpath.
Simple sketch of shape would help.
scottp55
Postby adze_cnc » Wed Jan 02, 2019 6:49 pm
I expect this is what is wanted. Simple loft in Rhinoceros. Presumption: 2 inch length.
Loft 1/2R to1/4R; 2" length
adze_cnc
Postby RayHari » Thu Jan 03, 2019 9:26 pm
This image shows what I want. The fluting is conical in the sense that it looks like a straight rhinocerous horn split length wise.
RayHari
Postby RayHari » Thu Jan 03, 2019 9:47 pm
Adrian wrote:Not many people read posts in the gadgets section as it's very specialised. You might get more responses if you post in the VCarve section with a picture of what you want to do.
Is there a way to move the thread to another section? Or do I have to do a fresh post in the general section?
RayHari
Postby highpockets » Thu Jan 03, 2019 10:10 pm
FixitMike wrote:You can do this in Aspire with a 2 rail sweep. But it is beyond the capabilities of VCarve as far as I can tell.
+1
I've tried several ways that I could think of, but can't get exactly what you want in VCP
Postby adze_cnc » Mon Jan 07, 2019 6:11 pm
highpockets wrote:I've tried several ways that I could think of, but can't get exactly what you want in VCP
John,
I expect it is possible to do what the poster want using the fluting toolpath. It's jut that you're going to need many toolpaths and not just one. It'll also involve some fancy drafting to layout the cut paths for half the semi-circle (semi-hemi-circle?) to get the required depths of cut for the start and end points.
Or one could model it in a 3D-program such as Rhino and cut it using a finishing toolpath...
Steven
adze_cnc
Return to Gadgets - General
