Dovetail Gadget
Dovetail Gadget
Postby MWinn » Sun Jun 03, 2018 5:02 pm
Hello,
I have been trying for weeks to get the dovetail gadget to work in VCarve Pro 9.
When I create my sides and attemp to create my PINs I get the screen in the attached screenshot.
It always only creates one end of the pins in the correct spot.
Any suggestions would be appreciated.
thanks
MW
MWinn
Model of CNC Machine: StepCraft 840
Re: Dovetail Gadget
Postby Adrian » Sun Jun 03, 2018 5:17 pm
Change the start node on the vector that is the wrong way round to be on the other end and that will sort it.
Re: Dovetail Gadget
Postby MWinn » Sun Jun 03, 2018 5:51 pm
Ah, that was the culprit,
tyvm
MW
MWinn
Re: Dovetail Gadget
Postby fredfow3 » Wed Jul 25, 2018 11:12 pm
Just a tip,
If you make the boxes and use the "Explode Vectors" gadget on them, it will make all the start points correct.
Cheers,
fredfow3
Model of CNC Machine: Laguna Swift 4x4, Shapeoko S3 XL
Re: Dovetail Gadget
Postby Belgard » Fri Aug 17, 2018 3:56 pm
So, on my dovetail gadget, it is inserting the pins backward or facing outward. I am following the tutorial to the T, and its just not inserting them correct... help
Belgard
Model of CNC Machine: shark extended bed 8.5
Re: Dovetail Gadget
Postby Adrian » Fri Aug 17, 2018 3:57 pm
Belgard wrote:So, on my dovetail gadget, it is inserting the pins backward or facing outward. I am following the tutorial to the T, and its just not inserting them correct... help
Have you changed the start node position?
Re: Dovetail Gadget
Postby Belgard » Fri Aug 17, 2018 4:08 pm
no, apparently not. How do I do that?
Belgard
Re: Dovetail Gadget
Postby Adrian » Fri Aug 17, 2018 4:18 pm
Go into node edit mode (press N) click on the vector and you'll see a green square at one end. Hover over the black node at the other end of the vector and press P to make that the start point. Rerun the gadget.
Re: Dovetail Gadget
Postby Belgard » Fri Aug 17, 2018 4:51 pm
thank you. it works!!!!!
Belgard
Return to Gadgets - General
