Corner / Radius Utility
Postby jalessi » Thu Aug 16, 2018 12:58 am
I am not sure if this already exists in any of the Vectric software however it would be awesome if is there a tool that would examine a vector and automatically adjust all corners for a specific radius, let's say the smallest tool is on hand is .250 and it needs to fit precisely into a corner or radius. The utility would need to check every corner or radius and make a adjustment so that all radius in the vector are at least the corresponding size or larger.
Any information would be greatly appreciated.
jalessi
jalessi
Re: Corner / Radius Utility
Postby IslaWW » Thu Aug 16, 2018 12:59 am
Look at the inlay toolpath. You don't have to run the female
CNC Technology & Training
IslaWW
Postby Rcnewcomb » Thu Aug 16, 2018 3:35 am
Method #2
Select all vectors
Offset OUTWARD by the RADIUS of the bit
Offset INWARD by the DIAMETER of the bit
Postby Adrian » Thu Aug 16, 2018 8:01 am
Use the Radius All Corners gadget - viewtopic.php?f=47&t=27848
Return to Gadgets - General
