.GetActiveSide
.GetActiveSide
How do I get the UUID for the SetActiveSide method in the VectricJob object.
Re: .GetActiveSide
GetSideList() and/or GetActiveSideId()
Re: .GetActiveSide
How do I find the actual value?. I can save the value to a variable but can't read the value in zerobrane, or do an if equal function on it.
I need to find if the job is 2 sided ,if it is flip to the bottom side do an operation , flip to top side, repeat operation.
Re: .GetActiveSide
GetSideList should give you both values so you can process from there I would think.
Re: .GetActiveSide
getsidelist() returns this "luaUUID list:2IDs".
Re: .GetActiveSide
What you display as a value isn't always the same thing as the value itself. I haven't tried it myself but in many languages displaying an object value will give you a human readable string rather than the actual value which you would get if you used the value directly as an argument to a function.
