utParameterList - VCarvePro
Postby Raedle » Sat Mar 17, 2018 4:57 pm
I'm trying to use the object utParameterList for a Job with out any success. I can set parameters but not get them. How do I add the parameter list object to the job? Please help. Thank you.
Code: Select all
function JobParameters(myJob)
  local dblValue
  local myParameterList
  --return utParameterList object
  myParameterList=myJob.JobParameters
  --Set a parameter
  myParameterList:SetDouble("TESTME",9.99)
  --try to get parameter -> this does not work! What is wrong with the call
  dblValue=myParameterList:GetDouble("TESTME",1.11,true)
  return
end
Raedle
Model of CNC Machine: Mach3 home-built high precision CNC
Re: utParameterList - VCarvePro
Postby Raedle » Mon Mar 19, 2018 11:57 pm
Below is code where :GetDouble() method works. No idea why a ; is needed at the end of :GetDouble() and third parameter (bool create_if_not_exist) must be omitted.
Code: Select all
  local dblValue
  --Set parameter
  --Get parameter
  dblValue=myParameterList:GetDouble("TESTME",0.0);   --<----
  MessageBox("Value" ..dblValue)
  return
end
Raedle
Return to Gadgets - General
Users browsing this forum: Google [Bot] and 4 guests
