Creating a circle with a gadget
Postby GrainDesign » Tue Dec 05, 2017 8:49 am
Hi there
I'm just learning how to create gadgets and was wondering what the easiest way of creating a circle within a gadget is.
I have tried to use the CreateCircle() global method but cant seem to get it to work it just keeps returning a nil value. (Maybe I'm doing something wrong)
Would it be easier to us the contour:ArcTo() method and us either 2 or 4 lines arced to make the circle.
any help would be appreciated.
thanks
GrainDesign
Model of CNC Machine: Ascent pro
Re: Creating a circle with a gadget
Postby Adrian » Tue Dec 05, 2017 10:13 am
This is a bit of code based on an example SDK script that draws a circle using CreateCircle.
Code: Select all
-- VECTRIC LUA SCRIPT
require "strict"
function AddGroupToJob(job, group, layer_name)
   local cad_object = CreateCadGroup(group);
   local layer = job.LayerManager:GetLayerWithName(layer_name)
   layer:AddObject(cad_object, true)
   return cad_object
end
function main()
    local job = VectricJob()
    if not job.Exists then
       DisplayMessageBox("No job loaded")
       return false;
    end
   local group = ContourGroup(true)
   group:AddTail(CreateCircle(0,0,20,0.0,0.0))
   AddGroupToJob(job, group, "Circle Example")
   job:Refresh2DView()
   return true
end
Return to Gadgets - General
