Layer Gadget
Layer Gadget
Postby GrainDesign » Wed Nov 08, 2017 8:02 pm
Hi there
I have made a gadget to add layers into a job. I am wanting to know if it is possible to assign each of those layers its own colour via the script also.
If it is possible how would I go about this?
GrainDesign
Model of CNC Machine: Ascent pro
Re: Layer Gadget
Postby Adrian » Wed Nov 08, 2017 9:48 pm
Colour (and Color) is a read/write property of CadLayer. Page 47 in the SDK documentation.
Re: Layer Gadget
Postby GrainDesign » Thu Nov 09, 2017 1:26 am
Thanks for you reply.
I am new to Lua and not sure how to execute this,
I have managed to get my gadget to add the Layers to vcarve but struggling to get the code right to add the colour to them.
I have tried the :SetColour() but must be doing something wrong because it just throws errors.
GrainDesign
Re: Layer Gadget
Postby Adrian » Thu Nov 09, 2017 8:00 pm
The following should work for you. The first two hex bytes are red, then green then blue. So for white you would use 0xFFFFFF and for black 0x000000. The example I've given is red.
Code: Select all
local layer = job.LayerManager:GetLayerWithName("Layer 1")
layer.Color = 0xFF
Re: Layer Gadget
Postby GrainDesign » Fri Nov 10, 2017 10:30 pm
Thanks Adrian
That worked,
I was very close with it but just had it the coding slightly wrong.
GrainDesign
Return to Gadgets - General
