First time dovetails
Postby dah79 » Wed Aug 09, 2017 1:51 pm
First time trying to use the dovetail gadget so my issue could be user related.
When trying to create a dovetail, based on the tutorial I watched, I get a different end result. My dovetails on one end are being created outside the initial shape. I see that if I change the start point, so that it is different on each end, then it works correctly. Is this a required step, as I didn't see that in the tutorial?
I have downloaded the V9 compatible version...
Dave
dah79
Model of CNC Machine: FLA Saturn 4x4
Re: First time dovetails
Postby dah79 » Thu Aug 10, 2017 11:54 am
Does nobody use this gadget? More curious if this was an issue with the 8.5 version.
Dave
dah79
Postby Adrian » Thu Aug 10, 2017 3:18 pm
Never had an issue with it like that but I always cut the vectors in the same order so I wouldn't have come across it. It works the same way as 8.5
Postby Dadof2and2 » Fri Aug 11, 2017 6:02 pm
I just tried to use it in ver. 9 I'm having the same unsuccessful results as you. The pins are also forming outside the original shape. Fortunately I did not uninstall 8.5. It works fine in 8.5. Looks like it needs some work for ver. 9. Glad I read your post or I'd still be messing with it.
Dadof2and2
Model of CNC Machine: Fine Line Automation
Postby dah79 » Fri Aug 11, 2017 6:13 pm
Thanks for letting me know. I hadn't tried it before V9.
Dave
dah79
Postby Adrian » Fri Aug 11, 2017 6:18 pm
It works in exactly the same way as 8.5 for me. You need to have the start point in the correct place in either version.
Postby Dadof2and2 » Fri Aug 11, 2017 6:47 pm
Looks like I was lucky when I tried it in 8.5. I tried it again in 9 making sure none of the lines shared a start point location and it works as expected. I stand corrected. It works fine. I've been waiting for this day for a long time. 70 years old and I finally made a mistake.
Dadof2and2
Return to Gadgets - General
