change all start points
Postby jeremysimmons » Fri Jul 28, 2017 3:56 am
http://support.vectric.com/aspire-quest ... tart-point
http://support.vectric.com/aspire-quest ... f-toolpath
start points are usually in a corner. is there a gadget or another way to change all start points to a flat edge?
jeremysimmons
Model of CNC Machine: xcarve 1000mm
Re: change all start points
Postby Adrian » Fri Jul 28, 2017 7:38 am
Version 9 has a new tab that lets you set the start point automatically for a toolpath.
Postby jeremysimmons » Sun Jul 30, 2017 8:30 pm
that's better than a poke in the eye with a sharp stick. It only works about 80% of the time to accomplish what I need.
I asked because I want to avoid the dwell marks caused by some runout I was having.
I believe my problem is better solved by using ramps, which keeps the bit moving while it descends.
jeremysimmons
Postby Adrian » Sun Jul 30, 2017 8:44 pm
Best way to avoid dwell marks is to use in and out leads. That way the plunge and retract is away from the part.
Postby PaulRowntree » Mon Jul 31, 2017 8:24 pm
Are you trying to re-orient the start points of a set of Vectors? GreenSquares gadget might help.
TreeSoft GreenSquares.pdf
(663.77 KiB) Downloaded 100 times
Paul Rowntree
PaulRowntree
Return to Gadgets - General
