Circle Resize
Circle Resize
Postby PeteSeminole » Tue Feb 28, 2017 2:54 pm
Having an issue with the Circle Resize as I selected all my circles to resize I entered in my current size with tolerance .01 and new circle size .7425 into gadget box. It says it found 4 holes to change but there is 17 holes total. When I go to do it again it says failed to find any .767 size holes. Attached is the file
Any one else have this similar problem ???
Pete
Counter Caddy TOPS only - NO Holes.crv
(103.5 KiB) Downloaded 74 times
PeteSeminole
Re: Circle Resize
Postby sylvan356 » Tue Feb 28, 2017 3:23 pm
Did you select them all before running the gadget?
sylvan356
Model of CNC Machine: CAMaster Stinger 1 w/Rotary, Aspire 9
Re: Circle Resize
Postby PeteSeminole » Tue Feb 28, 2017 3:40 pm
sylvan356 wrote:Did you select them all before running the gadget?
Yes I did
PeteSeminole
Re: Circle Resize
Postby Kayvon » Tue Feb 28, 2017 4:29 pm
If you select a single circle and go to node edit, is it really a true circle? VCarve/Aspire won't detect a collection of arcs as a circle, even if they form a circle. I have this problem every time I import certain .dxf files.
Kayvon
Model of CNC Machine: CNC Shark
Re: Circle Resize
Postby PeteSeminole » Tue Feb 28, 2017 5:53 pm
Kayvon wrote:If you select a single circle and go to node edit, is it really a true circle? VCarve/Aspire won't detect a collection of arcs as a circle, even if they form a circle. I have this problem every time I import certain .dxf files.
I did check that they are all complete circles not arcs, as I even drew them with "draw circle" command in VCarve pro. I even tried to re-load the gadget also.
PeteSeminole
Re: Circle Resize
Postby Adrian » Tue Feb 28, 2017 8:39 pm
How are you doing the select before running the gadget? The numbers you're quoting for the number of holes don't match up with what I'm seeing on the various layers.
I usually use the vector selector first to select all the holes that match my requirements before running the gadget.
Re: Circle Resize
Postby PeteSeminole » Tue Feb 28, 2017 9:04 pm
Adrian wrote:How are you doing the select before running the gadget? The numbers you're quoting for the number of holes don't match up with what I'm seeing on the various layers.
I am picking them as I am not using all the vectors on the screen.
PeteSeminole
Re: Circle Resize
Postby BrianM » Wed Mar 01, 2017 9:38 am
The gadget is failing because it is not recognising some of the circles as they have been mirrored at some point. We have fixed this for a new release of the gadget and hope to have this uploaded in the near future.
Brian
Brian Moran
Managing Director
Vectric Ltd.
BrianM
Vectric Staff
Re: Circle Resize
Postby PeteSeminole » Wed Mar 01, 2017 2:27 pm
BrianM wrote:Hi,
Brian
Thanks for the solution - I thought I was loosing my mind :o - only problem is I have a many holes to change by hand. Also I did use the mirror command when I made these parts.
Thanks again Brian :D Can you notify me when the update is ready !!
PeteSeminole
Re: Circle Resize
Postby BrianM » Wed Mar 01, 2017 3:30 pm
PeteSeminole wrote:...
The updated gadget has been uploaded to the gadgets.vectric.com site. After installing ensure that it says 'Version 1.2' in the bottom left corner of the dialog and you should be good to go.
Brian
Brian Moran
Managing Director
Vectric Ltd.
BrianM
Vectric Staff
Re: Circle Resize
Postby PeteSeminole » Wed Mar 01, 2017 3:57 pm
Brian
Thanks for the super fast fix - I just tried downloading it but still the old one so I will have to wait until the server refreshes
PeteSeminole
Re: Circle Resize
Postby Adrian » Wed Mar 01, 2017 4:47 pm
1.2 downloaded and installed ok for me.
Return to Gadgets - General
