Unwrapping train gets really weird
Postby wdwkr53 » Mon Jul 11, 2016 2:25 am
I am having trouble with this train unwrapping. I can do a long somewhat round object like a handle & it does fine with all sides. But when I use the same import technique, it gets weird. I can't seem to sort it out on my own. I uploaded screen shots to help explain what is happening. Diameter = 3", Length 6", Middle of object, Z = 3", Wrap X2A. My actual goal is to do a lion's head for the top of a walking stick that has a barley twist as the handle. Any suggestions?
long & somewhat round object does fine
train ready for import
train imported
train wrapped
wdwkr53
Model of CNC Machine: 8020 Extrusion
Re: Unwrapping train gets really weird
Postby mezalick » Mon Jul 11, 2016 10:00 am
Make sure you have the "Discard data below Zero plane" unchecked and when asked if you want to unwrap the model,,say yes..
Michael
Michael Mezalick
https://carveddetails.com/catalog-book/
mm@mezalick.com
mezalick
Postby wdwkr53 » Mon Jul 11, 2016 2:31 pm
The result is the same. The video says that unwrapping will ignore the last 2 checkmark options anyway.
wdwkr53
Postby mezalick » Mon Jul 11, 2016 3:40 pm
Can you send your file so I can look at it ???
Michael
mm@mezalick.com
Michael Mezalick
mm@mezalick.com
mezalick
Postby wdwkr53 » Mon Jul 11, 2016 4:04 pm
The stl of the train isn't allowed, but here is the saved crv. thanks.
Wrapped Output-train.crv3d
(311.5 KiB) Downloaded 84 times
wdwkr53
Postby mezalick » Mon Jul 11, 2016 5:11 pm
I would look at your setting again.
Here are some pictures of what I get when I unwrap a model.
Make sure you are clicking on "Yes" to unwrap it
Michael
My settings
Click "YES"
What my train looks like unwrapped
Train wrapped around axis
Michael Mezalick
mm@mezalick.com
mezalick
Postby wdwkr53 » Tue Jul 12, 2016 4:53 am
I finally got it by CENTERNG the train before importing the model. After that, I could get it to work every time. I do remember something about if the original is way off in space, then centering it will at least give you some place to start. I guess I will continue centering the objects and try some more. Thanks for you help.
wdwkr53
Return to Gadgets - General
