Unwrapping train gets really weird
wdwkr53
Model of CNC Machine: 8020 Extrusion
Post by wdwkr53 »
I am having trouble with this train unwrapping. I can do a long somewhat round object like a handle & it does fine with all sides. But when I use the same import technique, it gets weird. I can't seem to sort it out on my own. I uploaded screen shots to help explain what is happening. Diameter = 3", Length 6", Middle of object, Z = 3", Wrap X2A. My actual goal is to do a lion's head for the top of a walking stick that has a barley twist as the handle. Any suggestions?
long & somewhat round object does fine
train ready for import
train imported
train imported
train wrapped
train wrapped
mezalick
Re: Unwrapping train gets really weird
Post by mezalick »
Make sure you have the "Discard data below Zero plane" unchecked and when asked if you want to unwrap the model,,say yes..
Michael
Michael Mezalick
mm@mezalick.com
wdwkr53
Post by wdwkr53 »
The result is the same. The video says that unwrapping will ignore the last 2 checkmark options anyway.
mezalick
Post by mezalick »
Can you send your file so I can look at it ???
Michael
mm@mezalick.com
Michael Mezalick
mm@mezalick.com
wdwkr53
Post by wdwkr53 »
The stl of the train isn't allowed, but here is the saved crv. thanks.
Wrapped Output-train.crv3d
(311.5 KiB) Downloaded 228 times
mezalick
Post by mezalick »
I would look at your setting again.
Here are some pictures of what I get when I unwrap a model.
Make sure you are clicking on "Yes" to unwrap it
Michael
My settings
My settings
Click "YES"
Click "YES"
What my train looks like unwrapped
Train wrapped around axis
Michael Mezalick
mm@mezalick.com
wdwkr53
Post by wdwkr53 »
I finally got it by CENTERNG the train before importing the model. After that, I could get it to work every time. I do remember something about if the original is way off in space, then centering it will at least give you some place to start. I guess I will continue centering the objects and try some more. Thanks for you help.
