Hello
The small problem i have is when cutting the fingers, the drill bit cuts down to the bottom of the finger then moves along the hole than comes up, surely this cannot be correct and it must put too much load on the 3mm endmill.
Looking at the videos it looks like the bit only moves when the above the material, but i cannot be sure.
What ami i doing wrong?
Problem with Dovetail Gadget
Re: Problem with Dovetail Gadget
no one?
To be honest I don't understand the question. How do you expect it to work if it doesn't move through the material?
The bit moves into the material at full depth rather than the bit coming out of the material and then moving and then plunging into to the material.
I am cutting at 18mm and moving a 3mm bit into the material at full depth isn't very good for the bit.
Have you checked the pass depth on the bit in the tool database? I haven't used the gadget for a while and I'm not at my main machine at the moment but I don't recall it cutting in a single pass when I used it.
yep 1.3mm
( box2 )
( File created: Thursday May 12 2016 - 05:10 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 160.000, Y= 430.000, Z= 15.100)
(Toolpaths used in this file:)
(dovetails2)
(Profile 4)
(Tools used in this file: )
(61 = End Mill {2.93 mm})
N110G00G21G17G90G40G49G80
N120G71G91.1
N130T61M06
N140 (End Mill {2.93 mm})
N150G00G43Z30.001H61
N160S12000M03
N170(Toolpath:- dovetails2)
N180()
N190G94
N200X0.000Y0.000F1400.0
N210G00X111.599Y132.689Z30.000
N220G1Z0.000F1400.0
N230G1X110.278Z-15.100
N240G1Y131.496
N250G1X111.599Z0.000
N260G1Y130.304
N270G1X110.278Z-15.100
N280G1Y129.112
N290G1X111.599Z0.000
N300G1Y127.919
N310G1X110.278Z-15.100
N320G1Y126.727
N330G1X111.599Z0.000
N340G1Y125.535
N350G1X110.278Z-15.100
N360G1Y124.342
N370G1X111.599Z0.000
N380G1Y123.150
N390G1X110.278Z-15.100
N400G1Y121.958
N410G1X111.599Z0.000
N420G1Y120.766
N430G1X110.278Z-15.100
N440G1Y119.573
N450G1X111.599Z0.000
N460G1Y118.381
N470G1X110.278Z-15.100
N480G1Z30.000
N490G00X103.556Y132.689
N500G1Z0.000F1400.0
( Material Size)
(dovetails2)
(Profile 4)
N120G71G91.1
N130T61M06
N160S12000M03
N180()
N190G94
N220G1Z0.000F1400.0
N240G1Y131.496
N260G1Y130.304
N280G1Y129.112
N300G1Y127.919
N320G1Y126.727
N340G1Y125.535
N360G1Y124.342
N380G1Y123.150
N400G1Y121.958
N420G1Y120.766
N440G1Y119.573
N460G1Y118.381
N480G1Z30.000
N500G1Z0.000F1400.0
