Creat Staircase Column Tool Path with Vectric
Postby bswdcad » Tue Feb 23, 2016 7:09 pm
Hello. We have a lathe machine and need to make some columns for staircases like this one bellow.
The problem is that I couldn't find a way to wrap the shape along the X axis and produce a baluster.
The actual wrapping gadgets seems that are not working in this particular case.
Bellow is a video of achieving this:
Creat Staircase Column Tool Path: https://www.youtube.com/watch?v=I_8xsts0w5A
It is possible to make a Vectric gadget to wrap a shape along an axis for lathe machines?
bswdcad
Model of CNC Machine: MasterWood
Re: Creat Staircase Column Tool Path with Vectric
Postby rscrawford » Tue Feb 23, 2016 7:37 pm
Do you have a lathe, or an indexer? Very different. With a lathe, all you need is a 2 dimensional vector. No point in creating a 3D wrapped model.
For an indexer, you'd need a 3D model.
A lathe would be WAY faster and WAY better at cutting those columns.
Russell Crawford
rscrawford
Model of CNC Machine: CAMaster Cobra 408 ATC with recoil
Postby Rcnewcomb » Tue Feb 23, 2016 7:51 pm
Here is one way of doing it with Aspire. This was just a quick-and-dirty attempt. Zip file attached.
But Russ is correct. This could be done with a simple 2D toolpath much faster.
BalusterExample.zip
(1.81 MiB) Downloaded 108 times
Postby bswdcad » Tue Feb 23, 2016 8:17 pm
Thank you for the replays.
I have a Lathe machine. Have one dedicated axis that is rotating.
I know that I only need the 2D shape which is easy to draw. I just don't know how to wrap the 2D shape along the X axis and generate the G-code for the machine from Vcarve. Actually Aspire can do a two-rail sweep but the problem is that I have a licence only for Vcarve.
bswdcad
Postby Rcnewcomb » Tue Feb 23, 2016 9:39 pm
For your lathe do you just need to translate XY movements into ZY movements?
Postby bswdcad » Wed Feb 24, 2016 9:04 am
Rcnewcomb wrote:For your lathe do you just need to translate XY movements into ZY movements?
Yes. I need to wrap the Y axis and translate the XY movement into XZ movement.
bswdcad
Postby bravesoul » Wed Feb 24, 2016 12:27 pm
Vcarve Pro has the "Wrapping" gadget, easy to use, just need to use the appropriate post processor for indexing on X or Y axis. The post processor will do the translation of the x movement to b movement, I am wrapping the x axis with my lathe parallel to the y axis. I have a completely converted Rikon lathe (setup by Brady Watson) and it works great for 2d and 3d.
Joe
bravesoul
Model of CNC Machine: ShopBot PRT ALPHA 48"x96"
Postby bswdcad » Wed Feb 24, 2016 1:11 pm
Please can you give a short tutorial about your workflow. I just don't understand how you are achieving your result.
Vcarve Pro also have the Wrapping gadgets, just seems that they are built with other purposes in mind, I mean for indexer machines.
I have a lot of experience using routers but this is the first lathe machine I'm working with and I need to understand very precise everything to get good results.
bswdcad
Postby bravesoul » Wed Feb 24, 2016 2:20 pm
I guess my first question would be if you are using yours as a true lathe? or do you have a stepper motor attached to it? Mine can be used either way but so far I have only used it with the stepper motor being run by my cnc controller. As was previously mentioned, if you are using the lathe under it's own power, turned on a spinning, then you would only need the Y and Z moves, no X moves since you are not using X. You would also need it to run up and down the Y axis several times to be sure you don't leave any wood uncut. You also have to be very careful how fast you are spinning and the depth of the cut with each pass of the Y axis. Like I said I have not used mine running under it's own power but can imagine the issues that can come up. You would have to modify a post processor to leave out the X axis movements, translating only the Y and Z axis. Hope this helps.
Joe
bravesoul
Postby bswdcad » Wed Mar 16, 2016 10:12 am
bravesoul wrote:I guess my first question would be if you are using yours as a true lathe?
Yes, it is a true lathe exactly like this one: COSEN CNC WOOD TURNING LATHE
bswdcad
Postby IslaWW » Wed Mar 16, 2016 1:00 pm
You will not need to "wrap" the job to be able to cut the profile in your first post. Nor is a 3D model required. The profile can be cut on that machine with XY vectors.
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby bswdcad » Wed Mar 16, 2016 1:16 pm
IslaWW wrote:You will not need to "wrap" the job to be able to cut the profile in your first post. Nor is a 3D model required. The profile can be cut on that machine with XY vectors.
Ok. Understand this, but how I need to proceed to generate the gcode for lathe from a 2D shape? All the information I can find in this forum is about wrapped setups for doing this things.
bswdcad
Postby IslaWW » Wed Mar 16, 2016 2:13 pm
This thread may explain the process: viewtopic.php?f=5&t=21909
The lathe shown in your video will not require multiple passes, but the toolpath on vector process I the same.
Gary Campbell
IslaWW
Postby bswdcad » Wed Mar 16, 2016 2:32 pm
IslaWW wrote:This thread may explain the process: viewtopic.php?f=5&t=21909
Actually it is not explaining what I need to know. How I can get from Aspire a working gcode for lathe mashine, starting from a basic 2D shape.
bswdcad
Postby IslaWW » Wed Mar 16, 2016 3:00 pm
Here is a screenshot of the simple 2d vector (quick trace from your 1st picture) a profile toolpath "on vector" will yield the proper XY code. Z may have to be eliminated from the gcode file, or you may have to make a special postP that swaps the axes and removes code for the unneeded axes.
Gary Campbell
IslaWW
Next
Return to Gadgets - General
