Newbie question - I am wondering if I could use a core box cutter set up as a round nose in VCarve 8 to use on the chamfer gadget instead of a ball nose?
Any advise or suggestions would be appreciated.
I have a larger core box bit and think it would be much quicker. The shape of the bits is the same except for the size and wanted to seek opinion before I risked running it on machine and doing damage to me or machine. Machine is cnc shark pro hd extended.
bit in question is a Freud 18-112 3/4-Inch Diameter Round Nose Router Bit with 1/4-Inch Shank
New to the gadgets and the forum and I appreciate you patience.
use core box cutter instead of ball nose on chamfer?
- Model of CNC Machine: CNC Shark
- Leo
Re: use core box cutter instead of ball nose on chamfer?
For all intents and purposes - that is the same to the CNC code as a ball nose end mill
- BArnold
- Model of CNC Machine: SO2/XCarve hybrid w/NEMA23 on all axes
I've done something similar to what you described. I wanted a cove profile on an item I made, so I went to my drawer of regular router bits. I had to set up two toolpaths for the border of the frame; one for the cove cut and another for a full cut through with a straight bit.
Sweet. Thanks very much. I think I will dive in and give it a shot.
Thanks for the replies.
