I can not install Halftoner
gallego
Model of CNC Machine: HOMAG VENTURE 3M
Post by gallego »
Hello, I can not install Halftoner, the .exe file that is empty out, how will you work ?, thanks.
Re: I can not install Halftoner
Which program are you trying to install it for? The gadgets don't work on trial versions or on desktop versions.
gallego
Post by gallego »
Hi Adrian, and thanks for your answer.
The Aspire version is 8 and the problem is that the installer is empty, nothing.
Thanks and regards.
Is it the full Aspire 8 or the trial?
gallego
Post by gallego »
Hi Adrian, is the full version, but still the file is empty, there is that does not support, does not take anything, I have Windows 7
http://gadgets.vectric.com/halftoner.html
seanm
Vectric Staff
Model of CNC Machine: 6040 Desktop CNC
Post by seanm »
Hi Gallego,
I have checked the installer that is on the gadgets website and i can confirm it installs on both 4.5 and 8 versions of aspire.
can you delete the exe you have now, clear your web browsers cache and then download a new version of the gadget installer and try to install that.
Please also ensure that the aspire software is installed on the current user and registered.
Sean
gallego
Post by gallego »
Seanm Hello, I will do what you told me. I copied the installer, and took him to the gadgets folder, and open it there to install, is it ?, thanks
seanm
Vectric Staff
Post by seanm »
open the installer where you downloaded it to.
