Hello ,
I am trying to use the Gear Gadget and I keep getting a error message.
The error is in "On Lua Button Create_Gear Line 452, Attempt to call field 'Getn'( a nil value)
This is the error in a nut shell. anyone else see this? Thanks.
Charlie
Gear gadget error message
- Model of CNC Machine: 6040
Re: Gear gadget error message
Which version of Aspire/VCarve are you using? Which version of the Gear Maker gadget (version is bottom right of the entry form) and which parameters are you setting when creating the gear?
Hi Adrian,
I am running VCPV8.017 and Gear maker V1. I used the default settings when I opened gear maker. Thanks.
Charlie
Charlie
OK I installed the latest version.IT now works with VCPv8. Thanks.
