Sean, thanks heaps for that gadget. Is it possible to add "delete original vectors" check box to the gadget or is there an easy way to do this manually?
Regardless, a great gadget and thanks again to Sean & Vectric for listening.
GC
Radius gadget tweek required
- FixitMike
Re: Radius gadget tweek required
When you run the radius gadget, the selected vectors are still selected when it is finished. So if you want to delete those original vectors, simply press the delete key.
Thanks Mike. I had no idea that the the text was still selected. If you look close at the pic you can see it is but had you not pointed that out, I would not have noticed.
Good gadget for sure.
