I downloaded the Flower Maker gadget and installed it.
It is installed under Program Data>Vectric>VCarve Pro>V 7.5>Gadgets>Flower Maker, with the files Flower Maker.htm & Flower Maker.lua.
When I open VCarve 7.514 and try to use the Flower Maker gadget I get a small error window with "Script: (tail call) Line: Unknown ( ) attempt to call a nil value".
I installed the gadget out of curiosity to see what it would do but cannot get it to function, what am I doing wrong?
Dan
Flower Maker
Re: Flower Maker
where did you find Flower Maker
I can not find anything with that name
Dana Decker
Aspire 8 something
CaMaster Stinger I
Aspire 8 something
CaMaster Stinger I
- Model of CNC Machine: Homebuilt 24" x 48"
Re: Flower Maker
I discovered it in this post:
Re: Gadget programming
Postby Adrian » Mon Oct 20, 2014 6:00 am
This is the gadget. The presentations that go with it are at http://support.vectric.com/2013
Attachments Flower_Maker.zip(1.01 KiB) Downloaded 43 times
Dan
Dan
Re: Flower Maker
The gadget is setup as an example of how to use the ZeroBrane environment and needs some changes if you want to run it without debugging etc.
The attached version should work for you.
- Flower_Maker.zip
- (980 Bytes) Downloaded 527 times
Re: Flower Maker
Adrian,
Thank you very much for your assistance. That did the trick and it is now works for me.
Thanks again,
Dan
Thanks again,
Dan
