Gear Gadget
Gear Gadget
Postby dme2637 » Wed Oct 22, 2014 5:25 pm
I'm not sure if this is the right spot to post this but, is there any way to make a flat gear from the gear gadget?
dme2637
Model of CNC Machine: Self built from plans
Re: Gear Gadget
Postby FixitMike » Wed Oct 22, 2014 5:39 pm
A flat gear is called a rack. They are easy to make since the sides of the teeth are straight. Google "gear rack dimensions" to see what you need to draw one.
FixitMike
Re: Gear Gadget
Postby FixitMike » Wed Oct 22, 2014 6:11 pm
The attached file is for a 20 degree 1 DP (diametral pitch) gear rack. Reduce the size to suit the DP, for example a 5 DP rack would be 1/5th size.
gear rack.crv
(10 KiB) Downloaded 392 times
FixitMike
Re: Gear Gadget
Postby FixitMike » Mon Oct 12, 2015 6:13 pm
In order to cut a rack using a router, it is necessary to add a radius extending the dedendum.
FixitMike
Re: Gear Gadget
Postby dhellew2 » Tue Oct 13, 2015 6:18 pm
For those of us out there are 'somewhat or a lot gear challenged' there are a couple of software packages available at a reasonably low cost:
Gearotic 2.0 and Gear Template Generator
BOTH OUTPUT FILES TO MULTIPLE FORMATS
BOTH CREATE PRECISE GEARS
Gearotic 2.0 [formerly Gearotic Motion] does all types of gears, includes shafting, shaft layout, has 3d simulation, and about a hundred how to videos
Written by Art Finerty the developer of Mach3
Has a lifetime price of about $120 [all upgrades/updates are free for life]
In my experience Art Finerty an Bob Landry are super responsive to questions.
Videos can be accessed without owning the software
http://www.gearotic.com
Costs about $25
Creates lots of gears but does not include shafting, only one spoke design, no 3d viewing, requires a bit more technical knowledge than Gearotic 2.0
Dale
Dale
dhellew2
Return to Gadgets - General
