Box Making Gadget Toolpath
This forum lists all Gadgets that are available now
Postby PeteSeminole » Fri Oct 27, 2017 5:14 pm
I would like to make more than the (1) box of the same size that the gadget allows you to make. You can copy the vectors but you can't recalculate the toolpaths, as it says it's toolpaths are imported. Anyone have a worked around or a solution ??
PeteSeminole
Re: Box Making Gadget Toolpath
Postby Adrian » Fri Oct 27, 2017 5:44 pm
Which Box Making Gadget are you referring to? This one uses standard toopaths that can be recalculated.
Postby PeteSeminole » Fri Oct 27, 2017 6:09 pm
Adrian wrote:Which Box Making Gadget are you referring to? This one uses standard toopaths that can be recalculated.
Box Creator Gadget ver 1.0
PeteSeminole
Postby Adrian » Fri Oct 27, 2017 7:46 pm
Yes, that's the one I meant (I forgot the link). I haven't used it much but every time I have the toolpaths it creates are standard profile and pocket toolpaths that can be assigned to multiple vectors in the usual way.
Postby seanm » Mon Oct 30, 2017 9:28 am
It will be the dovetail toolpath that is a non-standard toolpathing strategy which cannot be recalculated. The Box creator gadget will be revisted in the near future and i will keep your suggestion in mind,
many thanks
Sean
seanm
Vectric Staff
Model of CNC Machine: 6040 Desktop CNC
Postby PeteSeminole » Mon Oct 30, 2017 2:56 pm
Thanks for the reply Sean. It would be great if you could nest multiple boxes whether they are all the same or different. For my solution I am going to try the dovetail gadget and see if I am able to make multiple copies of the same parts with toolpath geometry
PeteSeminole
Return to Gadgets - Releases
