- Highlight the object to want to balance
- Rotate the object so it's balancing left-to-right
- Move the object so its pivot is at x=0
- Run the gadget
Balancing/area gadget
- Model of CNC Machine: CNC Shark
This is a gadget I wrote for balancing clock hands. It can be used to determine the total area of an object and tell you how balanced the object is left-to-right. Usage is simple:
- Balance_Gadget.zip
- Balance/area gadget, v2017.02.19
- (2.34 KiB) Downloaded 528 times
Re: Balancing/area gadget
Thanks for sharing
- Model of CNC Machine: Emach EM900. KEW 1212
Kayvon wrote:This is a gadget I wrote for balancing clock hands. It can be used to determine the total area of an object and tell you how balanced the object is left-to-right. Usage is simple:
- Run the gadget
Silly question.. after unzipping the gadget how do you import or install it into V Carve 8.5?
- Model of CNC Machine: CNCRouterparts Benchtop Pro
Oh, don't say that. I'm looking for the same answer.
--Rich Farwell
--Rich Farwell
- highpockets
Make note of where you unzipped the gadget.slowoodworker wrote:Silly question.. after unzipping the gadget how do you import or install it into V Carve 8.5?
--Rich Farwell
In VCP or Aspire click on File->Open Application Data Folder
A Windows Explorer window will open to VCP data folders.
Click on Gadgets.
Copy the Balance_Gadget.lua into the Gadgets folder.
Close Explorer window and restart VCP.
Cheers for the info... Will have a play tomorrow
