Radius All Corners
This forum lists all Gadgets that are available now
Radius All Corners
Postby seanm » Mon Feb 16, 2015 3:00 pm
Radius All Corners Gadget
This Gadget will allow you to apply a radius to internal and external corners on your selected vectors.
How to use:
1. Select vectors you wish to apply a radius to the internal and/or externals corners. If you wish to add a radius to a text object, you must first convert this to curves by selecting the text and selecting this option from the right click menu.
2. Go to Gadgets on the software's toolbar and select "Radius All Corners"
3. Decide whether you would like to add a radius to either the internal, external corners or both and enter the radius value you would like to add to each. If you only would like to add a radius to one set of corners, then leave the other set with a value of 0.
4. Press ok to run the gadget or cancel to exit.
The gadget will create you a new set of radiused vectors on a layer called "Radius Corners". The gadget will also colour these vectors orange to help differentiate between vectors. Please note you cannot undo the result of this Gadget which is why we do not replace the original vectors.
You can download the gadget from this link:
http://www.vectric.eu/update/gadgets/v7 ... nstall.exe
seanm
Vectric Staff
Model of CNC Machine: 6040 Desktop CNC
Re: Radius All Corners
Postby scottp55 » Tue Feb 17, 2015 4:02 am
Thanks Sean!
scottp55
Postby GraClay » Wed Feb 18, 2015 12:18 am
Well done Vectric and thank you for listening. I have loaded and tried this gadget and the radius function is just what I needed.
There is however a slight mod required or maybe I need some advise on how to better use Aspire.
Presently the gadget leaves the existing vectors there so maybe if there was a checkbox in the gadget that says "delete original vectors" could be added?????
Regardless, I am grateful for this gadget.
GraClay
Postby GraClay » Wed Feb 18, 2015 12:24 am
Excellent gadget & thanks to Vectric staff for listening.
Is it possible add a cheque box "delete original vectors"? or is there an easy way to do this manually?
GC
GraClay
Postby GregP » Sun Aug 21, 2016 8:31 pm
thanks, I know I will use this a lot !
GregP
Postby LittleGreyMan » Sun Aug 21, 2016 8:40 pm
Nice and useful addition, thanks.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby BernieNUFC » Mon Aug 22, 2016 9:40 am
Literally 1 hour before i saw this i did over 100 corners :D
Have tried this and i am sure i will use it as it worked great on my trial, thank you
VCarve Pro v9.012
High-Zs 720- Kress 1050 router ( CNC-Step DE version)
BernieNUFC
Model of CNC Machine: High Z 720
Postby ryadia » Mon Jul 24, 2017 1:26 pm
Is there any chance this will work with version 9?
If not, is there likely to be a version 9 compatible gadget any time soon?
Ryadia
ryadia
Model of CNC Machine: 6040 USB CNC 4 axis Router/Engraver
Postby Adrian » Mon Jul 24, 2017 1:37 pm
Assuming you have a previous installation if you copy the "Radius_All_Corners" folder from "Public Documents/Vectric Files/Gadget" folder for the 8.5 version to 9 then you'll have it working in 9.
Postby ryadia » Tue Jul 25, 2017 4:09 pm
Adrian wrote:Assuming you have a previous installation if you copy the "Radius_All_Corners" folder from "Public Documents/Vectric Files/Gadget" folder for the 8.5 version to 9 then you'll have it working in 9.
Thanks Adrian. Does this apply to all/most Gadgets?
Ryadia :wave:
ryadia
Postby Adrian » Tue Jul 25, 2017 4:49 pm
Yes, until the installers are updated to v9 that's the only way to use the gadgets from the gadget site that I know of.
Postby Daner » Wed Dec 19, 2018 1:29 am
Where can I find this Gadget?
I looked under Gadgets, with no luck.
Daner
Model of CNC Machine: Industrial 8x4
Postby ozymax » Wed Dec 19, 2018 3:29 am
Just curious.
Did you read the opening post of this topic?
ozymax
Postby Daner » Fri Dec 21, 2018 11:16 pm
ozymax wrote:Just curious.
I did not see that link. :D
Daner
Return to Gadgets - Releases
