Automatic Dogbone Filleter - Toolpath Gadget
This forum lists all Gadgets that are available now
Postby seanm » Tue Oct 14, 2014 12:52 pm
Dogbone fillets are used to overcut into a corner when the application of the part you are making needs to fit tightly with another. When cutting out internal corners on a cnc you are left with a round corner due to the round tool you have used, you would need to manually finish off each of these corners with a sanding file to remove the rounded corner. With dogbone fillets you can use the cnc to overcut into these corners by the radius of the tool so that any mating material will be able to slot into place . This method is great for concealed joints where it will not affect the finish of the product.
To view more information about this gadget and other gadgets, please visit the Gadgets Website or for a direct link to this gadget click here
seanm
Vectric Staff
Model of CNC Machine: 6040 Desktop CNC
Return to Gadgets - Releases
