Aaron Leedham Phone Amplifer Drawing issue
Postby mrmfwilson » Wed Jul 25, 2018 1:34 am
Not sure where I should post this but there is a problem with the .crv file. The holes in the top inside pieces are not the same dimension as the corresponding holes in the sides. I moved the side holes to line up with the inside pieces. I have attached the files.
phone amplifier fixed.crv
(2.74 MiB) Downloaded 77 times
CenterLine Designs
Facebook - Centerline Designs
mrmfwilson
Model of CNC Machine: Legacy Arty 36
Re: Aaron Leedham Phone Amplifer Drawing issue
Postby Stephanie Downing » Wed Jul 25, 2018 12:30 pm
mrmfwilson wrote:Not sure where I should post this but there is a problem with the .crv file. The holes in the top inside pieces are not the same dimension as the corresponding holes in the sides. I moved the side holes to line up with the inside pieces. I have attached the files.
Thank you for sharing your updated file :)
Stephanie Downing
Vectric Staff
Model of CNC Machine: xxx
Return to Projects of the Month
