Mother's Keepsake Glue-up
Postby async4 » Thu Feb 02, 2017 10:13 pm
I hope someone has a trick to gluing up the mother's keepsake box? I find I have to be an octopus in order to assemble the 4 sides and bottom, and then try to clamp them with out them moving and smearing glue all over the place. Do I have to make a holding jig? If so, does anyone have a plan for one?
Thanx in advance.
async4
Model of CNC Machine: Shark pro plus
Re: Mother's Keepsake Glue-up
Postby SteveNelson46 » Thu Feb 02, 2017 10:25 pm
Michael has assembly instructions in this thread.
viewtopic.php?f=27&t=11147
SteveNelson46
Postby dwilli9013 » Thu Feb 02, 2017 10:32 pm
SteveNelson46 wrote:Michael has assembly instructions in this thread.
Man you guys are quick. Actually a couple of pictures in the thread to aide in the glue up clamp scheme.
viewtopic.php?f=41&t=11147
D-Dub
Dwayne
Dwilli
dwilli9013
Postby mtylerfl » Thu Feb 02, 2017 11:00 pm
async4 wrote:I hope someone has a trick to gluing up the mother's keepsake box? I find I have to be an octopus in order to assemble the 4 sides and bottom, and then try to clamp them with out them moving and smearing glue all over the place. Do I have to make a holding jig? If so, does anyone have a plan for one?
Thanx in advance.
Set the base onto scraps leftover from your cut parts. this serves as a platform to raise the base off the table surface.
Glue the back panel and two sides to the elevated base. Use masking tape to hold the parts if you wish, then glue on the front panel.
Check for square and clamp until dry.
Here's a couple photos for you...
EDIT: Thank you guys for adding that link. I forgot all about that! (my post is redundant - took over 45 minutes to upload due to icky internet here at the hotel I'm at in Ohio)
Postby async4 » Thu Feb 02, 2017 11:33 pm
Ya know what goes first with age? Memory! I am so thankful for you guys. I was trying to glue all 5 pieces at one time!
:D talk about a brain fart!
Thank you all so much!
async4
Return to Projects of the Month
