Free Project - Hinged Wooden Spoon Rest
Postby AmritpalP » Tue Jan 05, 2016 6:33 pm
For this month's project Michael Tyler has created an easy to make Spoon Rest project with a twist. This Vectric version features a hinged frame that swings up and over the bowl area to provide a built-in spoon handle support! Swing back over for compact storage. The slight angle of the handle support will help to keep drips from your spoons where they belong, in the spoon rest and off your counter top.
Note:
This free Vectric project requires Aspire 8.0/ VCarve 8.0 or higher.
Closed dimensions (approx): 4.875 " W x 5.25 " L x 1 " T
Open dimensions (approx): 4.875 " W x 8.875 " L x 1 " T
Click the link to download project files - [url]http://www.vectric.com/cool-stuff/projects/2016/Hinged-Spoon-Rest.html[/url
If you make your own version of this project, then it would be great to see a photo of your finished piece over on the Vectric Forum. Alternatively feel free to email us a picture of your finished piece at online@vectric.com.
Graphic & Web Designer
www.vectric.com
AmritpalP
Model of CNC Machine: ShopBot
Re: Free Project - Hinged Wooden Spoon Rest
Postby Ms Wolffie » Wed Jan 06, 2016 9:54 am
What is going on here?
You require password to download the monthly project :(
That's something new.
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Model of CNC Machine: SharkPro+HD Heavily modified
Postby JamesB » Wed Jan 06, 2016 10:12 am
I am afraid this was just a technical glitch at our end. Hopefully now it should be fixed and you can access the file, apologies for the inconvenience.
You will need to make sure to refresh the project page when you go back to it by hitting CTRL + F5 on your keyboard to overwrite the one in your browsers cache.
James
JamesB
Vectric Alumni
Model of CNC Machine: None
Postby Ms Wolffie » Sat Jan 09, 2016 10:32 am
Thanks James.
You had me worried for a while :D
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Postby dhellew2 » Thu Jan 14, 2016 11:40 pm
Make something, post it and it morphs.... Aspire/v-carve pro makes it really easy and fast.
Thanks to Michael for the ideas :D
Spoon holder modified by using offsets and a 1/8" brass pin for the hinge. [pin ends rounded-over with a hammer]
After doing the offsets I flipped the outer 'ring' about a line [vector drawn at hinge pin point] and moved it below the spoon holder.
1/8" hole drilled thru both parts at the same time using double sided tape [between parts] and painters tape [top and bottom]
Hole in center portion then drilled 1/64" over size.
Finish is Tung oil
Same tool paths for pocket and inside radius.
Made using northern red oak. When making thin parts pay attention to end grain in potential weak spots. In this case the end of the part that holds the spoon handle which is only 1/4" thick. First photo shows the flat-saw diagonal grain which multiplies the strength of the wood.
Drilling straight holes using inexpensive machinist tools from Harbor Freight and wood shims [plywood under end of spoon holder].
NOTE: tape was removed for these photos.
Dale
Dale
dhellew2
Postby mtylerfl » Tue Jan 19, 2016 5:20 pm
Very nice modification, Dale! Thank you for posting the pics and tips!
carvebuddy.com
Postby dhellew2 » Wed Jan 20, 2016 4:43 am
Michael, Alone we succeed, together we excel! Dale :shock:
Dale
dhellew2
Postby mtylerfl » Wed Jan 20, 2016 4:27 pm
dhellew2 wrote:Michael, Alone we succeed, together we excel! Dale :shock:
Hear, hear!
carvebuddy.com
Return to Projects of the Month
