Free Project - Big Buck Bank
Postby AmritpalP » Thu Sep 03, 2015 4:40 pm
For September Michael Tyler has created the perfect place to save and store you money. The Big Buck Bank project features a vcarve method to create engraved appearance of the front and back of an enlarged dollar bill. I got the inspiration to try this technique from a discussion on the Vectric Forum. The procedure used was to create thin component models of the front and back of a dollar bill image, import STL versions of each into separate instances of VCarve Pro 8, then create a finish toolpath with a large stepover setting to yield a line engraving effect.
Available for VCarve & Aspire V8.0 users.
The finished dimensions of this project are approximately 10.5 " W x 4 " D x 5 " T
Click the link to download project files - http://www.vectric.com/cool-stuff/projects/2015/Big-Buck-Bank.html
Graphic & Web Designer
www.vectric.com
AmritpalP
Vectric Staff
Model of CNC Machine: ShopBot
Re: Free Project - Big Buck Bank
Postby mezalick » Thu Sep 03, 2015 9:51 pm
Michael T,
All I can do is sit here and shake my head in amazement...
How in the world do you do it.
So Creative..
Thanks for the inspiration.
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Postby scottp55 » Fri Sep 04, 2015 8:32 am
Going to have to scope this one out just because of the
"import STL versions of each into separate instances of VCarve Pro 8" :)
Looks like a wonderful job Michael...again :D
scottp55
Postby Ms Wolffie » Fri Sep 04, 2015 11:56 am
Leaves me out :cry:
Nobody over here would pay for one with a US banknote on it.
And I ain't no Mr Turner to do something like that Sniff Sniff
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Postby mjeanson » Sat Sep 05, 2015 6:39 am
Nice work in combining a couple of techniques to result in a striking results on the dollar bill. I understand the basic concept to create a V-Carve path as the end result but what
I don't understand is how the two connected paths are created. First off how are you creating the raster vectors scan at 45 degrees from the STLs? What is in the STLs? Then once you have them are you by hand closing the ends of the two vectors to create the bounded V-Carve pocket? I would like to use this technique to create the illusion of a frog under the surface of lightly moving water for the top of a jewelry box.
mjeanson
Model of CNC Machine: Shark HD 60th Anniversary
Postby Adrian » Sat Sep 05, 2015 8:54 am
The PDF instructions that are in the project download explain how it's done.
It's not done with a VCarve toolpath it's done with a 3D finishing toolpath using a V-bit. The finishing path has a wide stepover to give the lines and is set at a 45 raster angle. The bounded edge is just two rectangles, one offset from the other.
The STL's were created by importing into Aspire using the Create Component from bitmap and then exporting as an STL.
Postby mjeanson » Sun Sep 06, 2015 6:08 am
Thank you. After using some of your key words in your post I was able to recreate the carving and thus recreate the effect on the STL in the project files that you provided. Will now be changing the linear spaced vectored paths to non linear raster effect ( Ripples ) to make it look like the object below is being viewed through a refracting surface (water in my case) that has small ripples on its surface.
mjeanson
Postby mtylerfl » Thu Sep 10, 2015 2:40 pm
Thank you all! I just read this thread today and I can honestly say "you've made my day"! YOU are my inspiration, encouragement and motivation.
Postby Gizmo's Gadgets » Sat Sep 12, 2015 8:18 am
New be to all the 3D stuff.
Outstanding work with the box.
I was hoping you could help me figure out what I am not doing right. I ordered and downloaded two projects. The app file showed up, I ran it and it installed OK. But the PDF files did not show up.
I did the download from this site. http://designandmake.com/project-shop/
Could they be hiding on my hard drive some place?
Gizmo
Gizmo's Gadgets
Model of CNC Machine: Home made table rounter
Postby Ms Wolffie » Sat Sep 12, 2015 10:20 am
Did you download the PDF Files separately?
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Postby Adrian » Sat Sep 12, 2015 8:08 pm
Gizmo's Gadgets wrote:New be to all the 3D stuff.
Gizmo
How do you know there should be a PDF with it? The projects I've bought from Design and Make didn't come with PDF's. They came with JPG picture files that are the guides which are installed in the same place as the project V3M files. The default folder is c:\users\public\public documents\Vectric Files\Designs&Make or the equivalent on your version of Windows.
Postby Gizmo's Gadgets » Sat Sep 12, 2015 10:19 pm
Found them. 8)
Gizmo
Gizmo's Gadgets
Postby cjskelton » Wed Jan 04, 2017 9:32 pm
I'm making the Big Buck Bank right now. I cut the dollar bill image on a piece of light gray corian type material. It turned out much sharper than the one I cut from wood. Here is a photo of the bill.
cjskelton
Model of CNC Machine: Probotix Meteor
Postby mtylerfl » Wed Jan 04, 2017 9:37 pm
That looks great on the Corian (or whatever solid surface brand it is)! Can't wait to see more pics when you are done.
Postby lathemaster » Tue Oct 17, 2017 5:46 pm
First thanks for a great project.
My wife gave our 4 yr old granddaughter $1 for helping her in the office.
She promptly told her mother that her granddad need to make her a wooden bank for her dollar.
Timing is everything.
Being a woodworker I did the top, front and back on my X-Carve 750 mm system
I cut out the other parts on the table saw.
I think if I make another I'll miter the box ends to spruce it up a bit.
I used poplar for the construction and a 20 deg. V-bit for the detailing on the top.
I do need to try Corian
Front View
Rear View
Thanks for looking
Mike
lathemaster
Model of CNC Machine: X-Carve 750
Next
Return to Projects of the Month
Users browsing this forum: grd750 and 2 guests
