Heian metric post
Heian metric post
I see there is a Heian (inch) post processor, does anyone have a Heian (mm) post?
Re: Heian metric post
Looking at this a little more.....
Could it possibly be as easy as changing the text for the units from "INCHES" to "MM"?? Seems too easy
POST_NAME = "Fanuc16 ATC Arcs (inch)(*.tap)"
FILE_EXTENSION = "tap"
UNITS = "INCHES"
POST_NAME = "Fanuc16 ATC Arcs (mm)(*.tap)"
UNITS = "MM"
UNITS = "INCHES"
UNITS = "MM"
- BrianM
- Vectric Staff
Hi CNCWoodGuy,
You will also need to change the G20 (inches) to G21 (mm) or possibly remove it.
Otherwise changing UNITS="INCHES" to units="MM" will change all the move units and feedrates from inches to mm.
There may be some other changes needed, although G-Code is supposed to be a standard there are a huge number of minor variations in each manufacturers implementation.
If you do change a post I would recommend you do a dry run without a tool in the chuck and with the z value set a safe distance above the table.
Brian
Brian
Thanks for the info.
