Mach 2 Mill
Mach 2 Mill
Help, can anyone help me eliminate tool path between text points. I am new to this and would like to know if there is text tutorial where it shows how to set up material to router. Thanks---Jim
- metalworkz
Re: Mach 2 Mill
Hello Jim,
It sounds like you may need to set your safe Z height in the 'Material Setup' section of the toolpaths tab window.
I think if left at zero the tool is probably dragging across the surface between the letters? I hope this helps.
