Hello!
When I have a circle in VCarve, then the resulting G-Codes are for circles in my machine file (G02/G03).
But when I mill a Circle and use Ramping -> Spiral then the G-Codes are made of hundreds of small linear segments (G01).
But spiral circles can be done with G02/G03.
Is this a normal behavior in VCarve? Or is it a problem of the Post Processor.
Thanks for any help
Jan
No Circles in Code when using ramping spiral
Re: No Circles in Code when using ramping spiral
Hello Jan,
This is correct - The postprocessor will not output arc moves
for spiral movement where the tool is moving simultaneously
in all 3 axes.
Tony
in all 3 axes.
Tony
Hello Tony,
thanks for your fast response!
Do you think this will be changed in the future?
Arc moves with Circles can be defined with normal G02/G03 Syntax.
So there is no reason to generate 400 lines of code instead of 3 lines.
But it is only a matter of time and filesize. The result is allways perfect.
Thanks Jan
Thanks Jan
