Legacy Artisan OM5 Mach3 Wrapper Post Processor
For those with Legacy Artisan's using Mach3 with the OM5 interface here is a modified post processor that will work with your standard "A Offset 6 G59". Both inch and mm versions are below.
- Mach3_Artisan_Wrap_inch.pp
- (4.41 KiB) Downloaded 514 times
- Mach3_Artisan_Wrap_mm.pp
- (4.34 KiB) Downloaded 454 times
Re: Legacy Artisan OM5 Mach3 Wrapper Post Processor
Anyone tried to VCarve or Toolpath text on a round yet? Getting a mirror image?
Here are the post processors again with the A-Axis reversed. This way you won't have to manually reconfigure your machine when switching between Vectric Products and Legacy Conversational CAM. You will notice the G-Code looks a bit different because it uses Mach3's math capabilities to multiply the A-Axis values by -1 within the G-Code.
- Mach3_Artisan_Wrap_Reverse_inch.pp
- (4.47 KiB) Downloaded 419 times
- Mach3_Artisan_Wrap_Reverse_mm.pp
- (4.46 KiB) Downloaded 412 times
If you want it to run backwards just change this,
ROTARY_WRAP_X = "-A"
To this,
ROTARY_WRAP_X = "A"
Greg
To this,
ROTARY_WRAP_X = "A"
Greg
Thanks Greg. That is even simpler. Here are the files again with the simpler fix for reversing A rotation and the modification to work with the "A Offset 6 G59".
- (4.45 KiB) Downloaded 408 times
- dealguy11
Will this postprocessor still work with Aspire 3?
Steve Godding
- Mark
- Vectric Staff
Hello dealguy11,
Yes, all post processors written for earlier versions of Aspire,
will work in version 3, without any modification.
I hope that this helps,
Cheers,
Mark.
Cheers,
Mark.
