Syntec 6mb post processor file
Postby Okie52 » Wed Jan 09, 2019 4:44 am
Does anyone have access to the Syntec rotary pp file for a rotary machine wrap x to y and also has atc
thanks
Okie52
Model of CNC Machine: Paranah next wave automation
Re: Syntec 6mb post processor file
Postby djcregan » Thu Jan 10, 2019 1:04 pm
Hi
I have two machines running Syntec controllers, both ATC (routers) one is a 6MB and the other is a 6 MD, will help you any way I can.
MANY THANKS
djcregan
Model of CNC Machine: Cnc Router with Linear ATC
Postby Okie52 » Fri Jan 11, 2019 12:05 am
Thank you
I was talking to manufacturer about purchase of machine with a side rotary and 180 degree rotating head.
My concern is that I use Vcarve pro but it does not have postprocessor for Syntec controller (Rotary axis).
I asked the manufacturer about the postprocessors and they told me, because the machine is 4 axis, it I did not need postprocessors ??
I know I can produce gcode for rotary but I am not sure I can produce code for 4th axis with vcarve.
My take on it is , with the side rotary, it is not true 4 Axis, just 3 Axis with y axis modified to rotary axis ?
Adding the 180 deg rotating spindle makes it true 4 axis ? Thus needing the 6mb controller ?
Do I need postprocessors ?
Okie52
Postby Okie52 » Sat Jan 12, 2019 11:49 pm
For any of you that have the same question
Here is what I have found out researching:
Sent email to Vectric ( No answer yet )
Does not need PP (FALSE) it does and 5 axis does !
I can not generate gcode for rotary with vcarve or ArtCam (no PP)
Rotary IS 4th axis.
I will have to purchase custom PP
or the possibility of editing another close PP
(still researching that) ??
Hope this helps someone else
Okie52
Postby LittleGreyMan » Sun Jan 13, 2019 10:42 am
Hello,
Okie52 wrote: or the possibility of editing another close PP
Did you have a look at the Help menu, item "Post Processor Editing Guide"?
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby Okie52 » Sun Jan 13, 2019 8:40 pm
LGM,
yes I am still researching
Thank you for the response.
I wll look at this
Okie52
Postby Okie52 » Sun Jan 13, 2019 8:54 pm
LGM,
I have never noticed that option ??!
Many thanks
Okie52
Postby pcmatthies » Wed Feb 06, 2019 3:50 am
I have a rotary atc with a syntec processor. Has anyone had any luck with a post processor listed in vectrics ?
Any help would be appreciated.
pcmatthies
Model of CNC Machine: 1325 atc
Postby Okie52 » Wed Feb 06, 2019 5:01 am
I can tell you that you are asking a hard one here.
They will tell you that the Syntec system is so programmable that each one needs it's own custom pp.
Which cam program are you using?
Dan
Okie52
Postby pcmatthies » Thu Feb 07, 2019 4:27 am
Aspire
pcmatthies
Postby pcmatthies » Thu Feb 07, 2019 4:30 am
The gcode atc works until it get to the line in the code M0
Then it stops, i can hit cycle start and it will continue until it gets to the next tool change and same problem.
I tried editing the processor deleting the M0 and it didn't work
pcmatthies
Postby Okie52 » Thu Feb 07, 2019 9:37 am
M00 in Syntec is dwell time. Is the gcode showing M0 or M00 ?
I am new to gcode also ?
I know there is a time set for dwell in the parameters.
Okie52
Postby Okie52 » Mon Feb 11, 2019 3:09 am
1. M00: Program dwell When CNC executes M00 command, the spindle will stop to rotate, feed will dwell, cutting oil will stop, it is convenient to size check and compensate for operator;We can specify the
program is dwell or not by “M00 cancel switch” on the interface.
2. M01: Selective program dwell M01 is similar to M00;but M01 is controlled by "selective
stop";when the switch is ON, M01 is effective, program dwell;
When the switch is OFF, then M01 is not effective.
Hope this helps
Okie52
Postby Okie52 » Mon Feb 11, 2019 3:29 am
G04: Dwell Command
X: specific time (decimal point permitted 0.001~
9999.999s)
P: specific time (decimal point not permitted)
Description: By specifying a dwell, the execution of the next block is delayed by the specified time. In addition, a dwell can be specified to make an exact check in the cutting mode.
Program example:
G04 X2500;//delay 2.5 sec
G04 X2.5;//delay 2.5 sec
G04 P2500;//delay 2.5 sec
G04 P2.5;//delay 2 sec (decimal point not permitted)
Okie52
Postby Humberto Ruiz » Mon Feb 11, 2019 5:11 pm
Hola a todos qualcuno que me pueda ayudar con este problema por favor, Cuando uso este postprocesor Mach2/3-WrapX2A ATC (mm), me crea un codigo G negativo y uno positivo y cuando uso el postprocesor Mach2/3 Arcs(mm) me lo escribe el codigo g perfecto. Yo tengo 4 ejes en mi CNC y estoy haciendo un desbaste igual hasta con la mismas medidas solo cambio el postprocesor y me genera el codigo G mal el Wrap.
( Desbaste 3D2 )
( File created: Monday February 11 2019 - 04:51 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 150.000, Z= 15.500)
( Diameter = 31.000 mm)
( X Values are wrapped around the Y axis )
( X Values are output as A )
(Toolpaths used in this file:)
(Desbaste 3D 1)
(Tools used in this file: )
(1 = Ball Nose {6 mm})
N130 G00G21G17G90G40G49G80
N140 G71G91.1
N150 T1M06
N160 G00G43Z3.000H1
N170 S12000M03
N180(Toolpath:- Desbaste 3D 1)
N190()
N200 G94
N210 Y0.000 A0.000 Z3.000 F2400.0
N220 G00 A277.236 Y-48.592 Z3.000
N230 G1 A277.236 Y-48.592 Z-1.500 F900.0
N240 G1 A-277.236 Y-48.592 Z-1.500 F2400.0
N250 G1 A-277.238 Y-48.586 Z-1.500
N260 G1 A-277.238 Y-47.992 Z-1.500
N270 G1 A277.238 Y-47.992 Z-1.500
N280 G1 A277.238 Y-47.392 Z-1.500
N290 G1 A-277.238 Y-47.392 Z-1.500
N300 G1 A-277.238 Y-46.792 Z-1.500
N310 G1 A277.238 Y-46.792 Z-1.500
N320 G1 A277.238 Y-46.192 Z-1.500
N330 G1 A-277.238 Y-46.192 Z-1.500
Pero cuando uso el postprocesor Mach2/3 Arcs(mm) crea el codigo G bien el ejemplo viene debajo.
( Desbaste 3D 1 )
( File created: Monday February 11 2019 - 04:50 PM)
( Material Size)
( X= 150.000, Y= 97.389, Z= 15.500)
(Desbaste 3D 1)
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (Ball Nose {6 mm})
N140G00G43Z3.000H1
N150S12000M03
N160(Toolpath:- Desbaste 3D 1)
N170()
N180G94
N190X0.000Y0.000F2400.0
N200G00X-75.000Y-48.592Z3.000
N210G1Z-1.500F900.0
N220G1X75.000F2400.0
N230G1X75.000Y-48.586
N240G1Y-47.992
N250G1X-75.000
N260G1Y-47.392
N270G1X75.000
N280G1Y-46.792
N290G1X-75.000
N300G1Y-46.192
N310G1X75.000
N320G1Y-45.592
N330G1X-75.000
N340G1Y-45.170
Humberto Ruiz
Model of CNC Machine: Auto construita, 4 ejes 1200mm, mach3
Return to Post Processors
