Hello,
I have an issue that I need to solve.
When I do a relief job and export a toolpath it is machined as on the video attached.
I selected raster, but it's rastered 'in parts' causing the artifacts shown on the photos at the end of the video.
https://youtu.be/O7B-LraZ9rEI need to have the surface uniform but it seems like the tool continued raised about 0,1mm above where it supposed to.
I tried to put material blocks in different heights in case of the issue with Z axis, but it appears at the same place.
Later I noticed it's because of how the toolpath is generated.
Tool will not do a full sweep of the model from bottom to top, but goes back and forth.
Is there any way I can force aspire to make the toolpath go from one side to the other with raster without lifting the tool?
Or how can I troubleshoot whether it's the machine issue or aspire/toolpath/Mach3?
I don't think it's the machine as tool was lifted more than once as seen on the video, but artifact happened only at that place.
Thank you for advice and help
