If conditions...
If conditions...
Postby ttishere » Tue Apr 24, 2018 11:48 am
Does the post processor supports if conditions?
ttishere
Re: If conditions...
Postby Adrian » Tue Apr 24, 2018 12:33 pm
Depends on the control language you're outputting. The SBP code my machine uses supports If conditions so I have them in my Post Processor but it's really a function of the SBP code not the PP code.
The Post Processor editing guide on the Cut2D/VCarve/Aspire Help menu shows which commands are available in a PP.
Postby ttishere » Tue Apr 24, 2018 12:43 pm
I'm looking to have "If tool number=1 then xxxx else xxxx".
ttishere
Postby Adrian » Tue Apr 24, 2018 12:51 pm
Like I say it depends if your control software supports If conditions. No problem with that type of statement on a ShopBot but I don't know about other systems.
Postby ger21 » Tue Apr 24, 2018 1:03 pm
The post processors do not support If...Then statements. There's a link to the post processor manual under Help.
What Adrian is referring to is that you can have the post processor output If..Then into the g-code, if your control supports it.
ger21
Return to Post Processors
