Post Processor needed for Anderson Selexx
Postby Branchy » Tue Apr 03, 2018 4:13 am
I have an Anderson Selexx with a 9 Drill bank. Im currently using this post processor attached (which I have edited myself to iron out a few issues), I’m now wanting to use my drill block, only problem is… this post processor doesn’t pick up the required M88/M89. Also how would I set these drills up in the tool database in Vectric V9.0 to tell the post which drills to use? Also if I was to use multiple drills at once… Is this possible? The rest of the post processor works fine with the normal head routing profiles etc. Any help is appreciated :)
Anderson_Selexx_Eco_ATC_mm_TR.PP
(12.79 KiB) Downloaded 136 times
Branchy
Model of CNC Machine: SCM Record 2 and Procam
Re: Post Processor needed for Anderson Selexx
Postby Rcnewcomb » Mon Apr 09, 2018 4:49 pm
You may need to contact Vectric support directly (suppport@vectric.com) I know they have done some work with drill banks in the past but have not released it as a standard feature.
Return to Post Processors
