Generic HPGL Vinyl Cutter Post Processor
Wemme
Post by Wemme »
Hello.
I recently purchased a Vinyl Cutter which was HPGL compatible however the software and drivers that came with it was rubbish.
So with a point in the right direction from Tony I wrote a post processor which works with the vinyl cutter.
I set up a Generic/Text print driver so that i can use the "output direct to device" from Vcarve.
I Post a copy of the PostP here for others to use at there own risk.
It works a treat for me and I am really chuffed that I can use Vcarve for my vinyl work.
A Big thanks to Tony.
If you use it or change it please post any details back in this thread.
Regards
Bart
Wemme
Post Processor
Post by Wemme »
PostP.
Generic HPGL Vinyl.zip
(637 Bytes) Downloaded 1980 times
Tony Mac
Vectric Alumni
Post by Tony Mac »
Nice one Bart!
zoltan
Post by zoltan »
Hi,
This is great. Could you tell me how you setup a General/Text printer driver? I am thinking about using this for my chinese laser to cut different materials, not only on vinyl cutter. Wow...I do not know how to setup the driver...
Thank you,
Zoltan
Wemme
Post by Wemme »
Hi Zoltan.
Here is a Quck PDF which shows you how to do it. use at your own risk.
keep in mind your hardware MUST support one of the direct output post processors other wise it's of no use.
Vinyl cutters and plotters mostly support at least HPGL.
Regards
Bart
zoltan wrote:Hi,
Thank you,
Zoltan
This is a Quick Guide on how to setup a Serial Driver for ….pdf
(443.9 KiB) Downloaded 1951 times
zoltan
Post by zoltan »
Thank you very much. I really appreciate it.
Zoltan
zoltan
Post by zoltan »
Hi,
Sorry for stupid question: how do you print directly from VCarve? What command do you use?
Thank you,
Zoltan
Wemme
Post by Wemme »
Zoltan.
Attached is a PDF.
If you cant click on "Device ..." then the post processor doesn't support Direct output.
Regards
Bart
zoltan
Post by zoltan »
Thank you, again.
Zoltan
Wemme
Post by Wemme »
zoltan wrote:Thank you, again.
Zoltan
No worries let us know how you get on.
Regards
Bart
Wemme
Post by Wemme »
Hello
Some more vinyl work using the above posted post processor.
Excuse the odd photo angles.
Regards
Bart
Geordiepom
Post by Geordiepom »
Hello again Bart
As I mentioned in the other thread I bought a Creation vinyl cutter. The software that came with it was pretty ordinary too. Next time I'm feeling geeky I'll give this a shot but in the meantime it ain't broke so I ain't gonna fix it. Thanks to you and Tony for this.
smphcc
Model of CNC Machine: AXYZ Millenium
HPGL Inch Post Processor
Post by smphcc »
Hi All,
Has anyone been able to get a direct PP out put from vcarve to a HPGL or DMLP plotter? Our Community College was going to dump 2 Houston DMP-60 plotters but I wanted to take a shot at converting them to vinyl cutter / engraver for High school students to use. Any info would be helpful.
Aloha
Danny
dmoore
Re: Generic HPGL Vinyl Cutter Post Processor
Post by dmoore »
Bart -
Thanks so much for investing the time into researching this - creating vinyl cutter files right out of VCarve is exactly what I want to do. In researching this, it apepars that some plotters support HPGL (not many) and some do. Can I ask what model Vinyl Cutter you have?
David
signmarketingman
Model of CNC Machine: Professional done home built.
Post by signmarketingman »
nearly all upper level cutters use hpgl (hewlet packard graphics language.)
Roland, Anagraph, summa, Graphtec etc.
Many low lever chinese cutters do not. They use revers notation or some other variant of graphics language.
