Hello
Have used Aspire for a while now for cutting cabinet parts. Have always had good luck cutting parts until recently. I'm getting over sized parts 1/32" and it is very consistent on all parts. I have been blaming bit deflection and vacume hold down but not able to find a feed rate or speed that changes this. Last week I was cutting two panels that where mirror copies of each other and the line bore shelf holes side stepped on one panel 1 inch. It was on only one line of the shelf holes. the other sheet is exactly what I had drawn a perfect line. Most of my problems started after updateing Aspire Not sure what is going on but would appreciate some help thanks
the post I'm running is Mach 2/3 arc atc
