Tape split doesn't work
Postby jpatton » Sat Jul 16, 2016 4:17 pm
I have been using tape split function through v-carve pro 8.0..However with the recent update, I haven't been able to use this function. When I try to save the tool path I get a writing error..Anyone know why or what I need to do to fix this. If I open 8.0 or lower it works fine.
Thanks in advance
jpatton
Model of CNC Machine: Shark HD Plus
Re: Tape split doesn't work
Postby Adrian » Sat Jul 16, 2016 5:48 pm
What does the error say exactly?
Postby jpatton » Sun Jul 17, 2016 9:42 pm
Sorry for the dealy- Work schedule..here is the message..Appreciate the help.
jpatton
Postby Adrian » Mon Jul 18, 2016 8:37 am
Is that the correct path? Seems a strange place to be saving toolpaths. Is that path the same in V8?
Postby jpatton » Mon Jul 18, 2016 4:30 pm
It doesn't matter where I try to save it too, that the message I get. albeit the location will change to where I try to save it too..Whether I try to a hard disk, flash drive etc. Like I say, worked fine up to version 8.5
jpatton
Postby IslaWW » Mon Jul 18, 2016 5:20 pm
In the off chance that that file is read only, have you tried saving under a different name?
CNC Technology & Training
IslaWW
Postby jpatton » Mon Jul 18, 2016 6:38 pm
Yes sir..I've tried saving under different names, locations even went into the folder and made sure it had read and write settings in the properties...I just don't know why it works fine up until the upgrade. I'm at a loss :?
jpatton
Postby mtylerfl » Tue Jul 19, 2016 2:45 am
jpatton wrote:I have been using tape split function through v-carve pro 8.0..However with the recent update, I haven't been able to use this function. When I try to save the tool path I get a writing error..Anyone know why or what I need to do to fix this. If I open 8.0 or lower it works fine.
Thanks in advance
Have you contacted Vectric Support and sent them the file? They will be able to tell you what's up.
carvebuddy.com
Return to Post Processors
