Help with a post processer
Postby tim mck » Sat Feb 13, 2016 10:05 am
We are upgrading our old CNC to a new Kimla CNC . Standard 3 axis, metric and a tool changer. I have put a link for the machine. Now what and how do I go about getting the post processor changed in Aspire. I know how to select the different P/Processors and output, but its more to do with which and what one is the right one? Just looking for some one to point me in the right direction.
Tim
http://www.kimla.pl/en/produkt-52-Indus ... NC-plotter
tim mck
Model of CNC Machine: Kimla CNC
Re: Help with a post processer
Postby Adrian » Sat Feb 13, 2016 10:46 am
It's the control software used to control the machine (Mach3/4, WinCNC etc) that is the important thing rather than the machine itself most of the time.
Do you know what control software it uses? If it's a proprietary one do you know if it's g-code based?
Postby LittleGreyMan » Sat Feb 13, 2016 12:50 pm
From the manufacturer website wrote:In case of machining complex 3D shapes we can also use CNC ISO files which are generated by any CAM system, including circular interpolation, helical and circular 3D, as well as the operation of 5-axis machines with dynamic translation the path to the length of the tool.
Choose a standard ISO postprocessor, with ATC (automatic tool changer) and circular interpolation
Begin with air cut at slow speed, set the Z0 higher than the table, use simple test paths and be ready to push the emergency switch. If you can lower the speed on the CNC control panel, use this command to slowly increase speed from 0 to the toolpath value.
Beware of circular interpolation: if you are in the wrong mode (relative or absolute), your CNC may try to jump from one point to another one, far away.
HTH
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby tim mck » Sat Feb 13, 2016 9:30 pm
Question,
Where will I find a ISO post processer?
Tim
tim mck
Postby LittleGreyMan » Sun Feb 14, 2016 10:32 am
The ISO post processors are named gcode_something and part of the standard installation.
"Something" includes mm or inch, arc for pp with circular interpolation and ATC for automatic tool changer.
You'll probably have to edit them for your machine to combine ATC and arc and check if you're in the right arc mode.
Always work on a copy of the original pp.
No rocket science, but you'll have to be careful when you'll check it.
You'll find a pp guide in the help menu of your Vectric software.
HTH
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby tim mck » Tue Feb 16, 2016 10:18 pm
Thanks for the help.
Tim
tim mck
Return to Post Processors
