I am working with a ShopSABRE 4896. When I output from the VisualMill post processor all is OK. When I output from Aspire 8, selecting ShopSabre post processor, loading the file to the CAM (Mach3, I think), it complains and will not run. VisualMill output has spindle start and a z value on nearly every line, Aspire has neither. Am I missing a setting somewhere?
Thanks in advance for any suggestions.
Al Allison
Aspire v8 on a ShopSABRE 4896
- Model of CNC Machine: Shop Sabre 4896
- larrybadgett
- Model of CNC Machine: ShopSabre
Re: Aspire v8 on a ShopSABRE 4896
Unless things have changed a ShopSabre would be using WinCNC processor. You would then use ShopSabre(inch-lines-arcs) for the post processor which does in fact list each axis on each line. The post processor that I use on a ShopSabre I have modified to start and stop the spindle and vacuum.
Larry,
Thank you very much for the reply. I have since checked and it is WinCNC. I must have selected the wrong post-processor. This is a machine from work, so I will have to wait till Monday to try it out.
Will you please give me a bit more guidance on what i need to do to work the spindle control in?
Thank you very much for your assistance.
Al Allison
Al Allison
- larrybadgett
Al
Go to the post processor editing guide found in Aspire drop down help menu. You will have to add the appropriate M code for the output that you want to turn it on and off.
Hi Larry,
Thank you again. I am reading through that information now.
Al Allison
Al Allison
