edit post processor
edit post processor
Can you tell me how to edit the gcodes (.tap) post processor file to elliminate the beginning and ending codes so my machine can use it (so I don't have to do this with every file-- thanks
The postprocessors are in the folder named,
C:\Program Files\VCarve Wizard 2.0 or PhotoVCarve\PostP
Make a Safe Copy of the Postp you wish to change.
Use a text editor such as NotePad to open the file you wish to modify
The postp has a very simple structure,
begin HEADER
"T1M6"
"G17"
"G0[ZH]"
"G0[XH][YH][S]M3"
Simply remove / edit as required ensuring that the required syntax is enclosed in " "
begin FOOTER
"G0[ZH]"
"G0[XH][YH]"
"M30"
Save the modified file ensuring you replace the original.
Important - By default NotePad will save the file with a .TXT extension which will
create a file that doesn't get opened by the software.
Make sure the new file has a .PP extension
You can always e-mail the changes you require to support@vectric.com
and we will send you the modified postp.
Tony
begin HEADER
"T1M6"
"G17"
"G0[ZH]"
"G0[XH][YH][S]M3"
begin FOOTER
"G0[ZH]"
"G0[XH][YH]"
"M30"
Tony
