Laser Control
- Model of CNC Machine: Optimum BF30
Laser Control
Hi Guys,
Can anyone tell me how to make V carve pro install the correct commands to turn a laser on and off in Mach3 please.
I believe it can be done with the Z axis or using M3, M5 commands or M10P1 / M11P1 or E1P0 / E1P1 commands.
ANY HELP APPRECIATED, thanks.
Re: Laser Control
Have you looked at the Post Processor editing guide on the VCarve Help menu? I don't know what actual commands you would need to control the laser but the guide will explain how and where to add them.
- Model of CNC Machine: home built shopbot clone. CNC lathe
Re: Laser Control
I have a pp I use to turn a plasma on and off with a delay for pierce. Send me your email and I will send it to you. It uses m08 but could be changed to m03 but you would want to change your spindle spin up in Mach.
Don Clifton
Dclifton2@cfl.rr.com
Don Clifton
- Model of CNC Machine: MechMate
Re: Laser Control
You can use M7 mist control.
Re: Laser Control
Can someone walk me through this please.
I have read the PP help menu on VCP. Result: NO HELP Maybe its just my thick head.
For instance, how do I tell the PP where and when to put these commands. Which command should I use? M3/5, or M10P1 / M11P1 or E1P0 / E1P1 or even Mist control.
I AM SO CONFUSED A huge thanks for all those trying to help on this.
Re: Laser Control
HUGE thanks to Dclifton for sending me the PP. Thats what I needed all along.
With the right PP its super easy. Well fairly easy at least. Only problem is Don's PP is imperial and that seems to be causing me some issues. Does anyone here have the metric version. As that's all we work in here down under.
Thanks. Warren.
Thanks. Warren.
Re: Laser Control
Warren
Not home right now, I will send you something tonight.
Greg in Geelong
Greg in Geelong
Re: Laser Control
Thanks Greg, look foward to it.
Re: Laser Control
Sent you a PM Warren.
Greg
Greg
Re: Laser Control
OOOK, how does one view ones PM's on this forum. I can't find your PM Greg. I clicked on Control Panel up top and then on Private Message.... only to be told I can't send PM's.
Well I don't WANT to send one ...I want to READ one.
Any help guys... Sorry for another dumb-ass question!
Re: Laser Control
At the top between where it says FAQ and Search you should have a link that says "n new messages" where n is the number of messages you have. Click on that and it will take you directly to the private messages.
You can get there by the route you were taking as well but you have to click on the Inbox link on the left to get out of the Compose new message form which is where you got to.
Re: Laser Control
Nope, no link there. Must be that Greg didn't send me the PM after all...
Re: Laser Control
Yeah I did.
It is still sitting in my out box, which means that you have not retrieved it yet.
All it said was, PM me your email address and I will send you a PP and info for the laser.
Greg
Greg
Re: Laser Control
laserpilot,
Open your User Control Panel and be sure you have the settings checked to send/receive PMs.
Tim
Tim
Re: Laser Control
DID THAT!! Everything is set to YES
Greg, could you PM me again please, hopefully it will work this time.
