Deskcnc postprocessor
Hello i have a vcarve and my machine have a deskcnc board. Who is the best postprocessor for it.? Thank you very much¡
- zeeway
Re: Deskcnc postprocessor
If you are using Mach 3, use one of those post processors.
Angie
Angie
- zeeway
...sorry...should have added...if you are using Mach3 for your control software...after you click the "generate toolpath" icon, you can choose the post processor from the drop down box at the bottom. I use Mach 2/3 Arcs (inch)(*txt)...if you do your designs in metric, you should choose the alternate noted for mm.
Angie
Angie
ok! but vectric not have a one postprocessor "special" design to deskcnc?
thank you Angie!
thank you Angie!
The latest version of VCarve Pro has 3 post processors for the DeskCNC machine.
What version of VCarve Pro are you using?
Tim
Tim
hello Tim, i used the Vcarve 4.6
thank you!
thank you!
Eugenio,
Have you checked to see if you have the three post processors I show in your postp folder?
I would think you need the DeskCNC_GCode_mm one to try first.
If you don't have them, or they don't work for you, it may be best to contact support@vectric.com with the details of your machine and they will help you.
Tim
Tim
hey Tim, i delete my computer complete and then reinstall all software again and.... surprise!!!! the vcarve pro! have a three postprocessor to deskcnc!
and i am sorry to you Tim and Angie for lost your time!
lately my computer not run correctly! and maybe i have very trash in the computer, but after the format and reinstall... all works OK!!!!
thank you again Angie, Tim.
Euge!
Euge!
- zeeway
de nada...
Angie
Angie
