Hi, Is there anyone with aMulticam metric pp,i am using winp-nc,with a Muticam output
The Multicam company supports only Muticam router owners.
arjen
multicam
Arjen,
We do have metric postp's for the MultiCAM and I thought you had copies of these?
Please e-mail details of what you need to - support@vectric.com
Neal,
If you send us a sample toolpath and any associated information that show what's needed
to run the ATC on your machine, we can take a look at modifying the postp.
Tony
Neal,
Tony
Tony,
Our Multicam does not have an ATC per se, but it does have 2 Z's that can operate together or as 2 seperate Z's using 2 different tools. We also use Enroute, it offers a ATC setup dialog box for the number of and type of tools, then the post will output the toolpaths & tools as long as they are spec'd in the ATC's setup. I could send you a mm .plt file with the tool change info using Enroute's PP, if this would help.
Neal
Neal
