Axiom post Processor MM vs Inch
Postby tjimholte » Sat Nov 03, 2018 5:57 pm
I am somewhat confused on the Axiom post processor. There is only one and it uses MM instead of inches. Is there a way to change that?
It appears that when I set a feed rate of 100 inches / min in my tool data base the machine runs at around 4 inches / minute which makes sense if you do the math 100 / 25.4 = 3.93.
Do I need to only use MM when defining feed rates?
Any thoughts are appreciated.
TJ
tjimholte
Model of CNC Machine: Axiom Pro 6+
Re: Axiom post Processor MM vs Inch
Postby IslaWW » Sat Nov 03, 2018 6:21 pm
TJ...
You are conflating units. 100 IPM =~ 2500mm/min = 1.666 in/sec = 42mm/sec.
There is a feature in your controller that may use a preset internal feed instead of the programmed feed, make sure that is enabled.
You can test by making a 20" line, set to 100IPM and aircut on the machine. It should take 1/5 minute or ~12 seconds with a little cush for ramping up and down
CNC Technology & Training
IslaWW
Postby gkas » Sat Nov 03, 2018 10:20 pm
Everything in the Vectric software can be defined in inches (Imperial) or Metric. The software will convert, as needed, to what your post processor requires. I work 99% of the time in Imperial, but my tools are defined in both Imperial and metric. If I have a 3mm bit, I define it as 3mm. I always define my feed rates as Imperial (in/min), because that's what I've tested.
The bottom line is that you only have to talk metric to your Axiom when you enter numbers into your handheld. It only knows metric; Distances, puck thickness, are all in metric.
gkas
Model of CNC Machine: Axiom AR8 Pro+
Postby tjimholte » Wed Nov 07, 2018 11:39 pm
Thanks Gary and GKAS,
I like the idea of just running an aircut 20 inch line to validate it is using the right speeds vs some default.
Do you know how to see if this processor is using some preset default other than what I tell it in the tool data base?
Thanks again.
TJ
tjimholte
Postby gkas » Wed Nov 07, 2018 11:52 pm
tjimholte wrote:Thanks Gary and GKAS,
It gets the ipm, etc. from the tool database. It gets the RPM from the front panel of the Axiom; i.e. it's set manually.
gkas
Return to Post Processors
