Guys,
Hoping someone can help?
I have just purchased VCarve Destop software and going through the video tutorials.
Every time I create a project either from following the tutorial or my own very simple project the cutter dives down to .5".
I have set up a simple pocket cut of 0.125 and every time the cutter follows along the pattern but 4 times the depth.
I'm using UGCS, xPro Controller V3 and VCarve Desktop. Post processor used in VCarve is G Code (inch)(*.tap)
I have run a small pocket cutout created in MakerCam, this run successfully.
I have tried all relevant G Code and gbrl PP's without success.
Would appreciate any ideas or thoughts as I am well and truly stuck.
regards
Tony
VCarve PP issues
Re: VCarve PP issues
Where are you setting the Z-zero? Material surface or table surface? Is it matching in VCarve and your control software?
An update.
I run the same small pocket test design with Cut2D this worked fine. With both MakerCam and Cut2D working okay the finger firmly points at VCarve. Both Cut2D and VCarve are Vectric pieces of software. My thoughts turned to application conflicts so I uninstalled both Cut2D and VCarve. I then reinstalled VCarve and run the test again, this time it worked perfectly.
It looks like Vectric cannot work with 2 applications installed.
- Model of CNC Machine: EZ-Router
Strange that you have that issue.Lodds wrote:It looks like Vectric cannot work with 2 applications installed.
I have Aspire, Photo VCarve and Cut 3D installed and Never had these issues.
Are you sure you selected the correct Post Processor?
As Adrian said are you setting Z-zero correct?
Vectric software can definitely work with two or more versions installed. I have multiple versions of Cut2D, VCarve and Aspire all installed and working perfectly. The post processors and program settings are all kept totally separate so there can't be a conflict between the different programs.
Rather than uninstalling you should have checked the settings between Cut2D and VCarve to see what was different. We'll never know now but the only thing I can think of (assuming the correct post processor was being used) is that the Z zero settings were different.
