hi all,
working with my joes 4x4 4th axis which uses mach3 for the driver
the optimized raster and the raster left little tits all along the piece ( using 1/2 ball nose at 10% stepover ) they really did not work the way i thought they would.
rather than just going back and forth they would also sometimes rotate the piece while going back and forth
this by the way is using the Y to A PP
so i decided to try the radial.
heres the file produced by the pp
all it did is stutter from x 0 to 18 while the A axis did not move.... not what i wanted
i edited it and got it to work( spindle moves over, A axis rotates, repeat till done) with this file
what i think worked is i replaced the A-360 with A359... is the pp right and i need to fix something or is it wrong ?
rounding toolpath radial with mach 3
- sawmiller
- ROUNDI~4.TXT
- file produced by the ytoa pp
- (25.85 KiB) Downloaded 275 times
- ROUNDI~3.TXT
- file that worked
- (18.83 KiB) Downloaded 251 times
In the heart of Tn
In the heart of Tn
- sawmiller
Re: rounding toolpath radial with mach 3
under general config, rot 360 rollover was checked. that was probally the cause, will do another tomorrow to make sure.
sigh... dan
sigh... dan
In the heart of Tn
In the heart of Tn
- sawmiller
yup, was the 360 rollover.
do NOT check this in the general config for mach 3 .
does not interpret Vectric's pp properly.
dan
dan
In the heart of Tn
In the heart of Tn
